Models supporting use of the headphones' mic for recording and use of the headphones for monitoring by connecting wirelessly to the ECM-W5 wireless microphone and the ECM-W5R wireless receiver are listed below.
- ◯: Supported
- ー: Not supported
November 11, 2026 *4 added
| Model name | Connection mode | Mic function *1 |
Monitoring function *2 |
Binaural recording function *1*3 |
| 1000X THE COLLEXION (WH-1000XX) | Classic Audio/LE Audio support | ◯ | ◯ *4 | ー |
| WF-1000XM6 (FW 2.0.0 and later) | Classic Audio/LE Audio support | ◯ | ◯ | ◯ |
| WF-1000XM6 (Prior to FW 2.0.0) | Classic Audio/LE Audio support | ◯ | ◯ | ー |
| LinkBuds Clip (WF-LC900) | Classic Audio only | ◯ | ー | ー |
| INZONE H9 II (WH-G910N) | Classic Audio/LE Audio support | ◯ | ◯ *4 | ー |
| WH-1000XM6 | Classic Audio/LE Audio support | ◯ | ◯ *4 | ー |
| WF-C710N | Classic Audio only | ◯ | ー | ー |
| LinkBuds Fit (WF-LS910N) | Classic Audio/LE Audio support | ◯ | ◯ | ー |
| LinkBuds Open (WF-L910) | Classic Audio/LE Audio support | ◯ | ◯ | ー |
| WF-C510 | Classic Audio only | ◯ | ー | ー |
| ULT WEAR (WH-ULT900N) | Classic Audio only | ◯ | ー | ー |
| INZONE Buds (WF-G700N) | LE Audio only | ◯ | ◯ | ー |
| WF-1000XM5 (FW 2.0.1 and later) | Classic Audio/LE Audio support | ◯ | ◯ | ー |
| WF-1000XM5 (Prior to FW 2.0.1) | Classic Audio only | ◯ | ー | ー |
| WF-C700N | Classic Audio only | ◯ | ー | ー |
| WH-CH520 | Classic Audio only | ◯ | ー | ー |
| WH-CH720N | Classic Audio only | ◯ | ー | ー |
| Float Run (WI-OE610) | Classic Audio only | ◯ | ー | ー |
| LinkBuds UC (WF-L900UC) | Classic Audio only | ◯ | ー | ー |
| LinkBuds S (WF-LS900N) (FW 3.0.5 and later) | Classic Audio/LE Audio support | ◯ | ◯ | ー |
| LinkBuds S (WF-LS900N) (Prior to FW 3.0.5) | Classic Audio only | ◯ | ー | ー |
| INZONE H7 (WH-G700) | Classic Audio only | ◯ | ー | ー |
| INZONE H9 (WH-G900N) | Classic Audio only | ◯ | ー | ー |
| WI-C100 | Classic Audio only | ◯ | ー | ー |
| WH-1000XM5 | Classic Audio only | ◯ | ー | ー |
| LinkBuds (WF-L900) | Classic Audio only | ◯ | ー | ー |
| WH-XB910N | Classic Audio only | ◯ | ー | ー |
| WF-C500 | Classic Audio only | ◯ | ー | ー |
| WF-1000XM4 | Classic Audio only | ◯ | ー | ー |
| WH-1000XM4 | Classic Audio only | ◯ | ー | ー |
| WF-SP800N | Classic Audio only | ◯ | ー | ー |
| WI-SP510 | Classic Audio only | ◯ | ー | ー |
| WH-CH710N | Classic Audio only | ◯ | ー | ー |
| WF-XB700 | Classic Audio only | ◯ | ー | ー |
| WF-H800 | Classic Audio only | ◯ | ー | ー |
*1 Cases where the headphones are used as the input mic by selecting the following menu item in the Control menu
SYSTEM → MODE SELECT → TWSMIC MODE
*2 Cases where the headphones are used as the monitoring device by selecting the following menu item in the Control menu
SYSTEM → MODE SELECT → 2TX MODE
*3 On compatible models, you can select BINAURAL ON/OFF from TWS MENU in the Control menu.
(These options are grayed out on incompatible models.)*4 Please update the ECM-W5/ECM-W5R to Ver. 1.1 system software, scheduled for release in the second half of November 2026 or later.
Using LE Audio on Sony headphones with LE Audio support
Before pairing with the ECM-W5 and ECM-W5R, make sure to use the Sound Connect smartphone app to switch to the LE Audio connect mode.
You can find detailed information on the Sound Connect smartphone app here.
https://www.sony.co.jp/en/sca/
Hint:
If you connect to the receiver before using the Sound Connect smartphone app to switch to the LE Audio connect mode, the connection will be in the Classic Audio mode, and you will not be able to use the monitoring function or binaural recording function. To switch to the LE Audio connection mode, first cancel pairing between the receiver and headphones and then use the Sound Connect smartphone app to switch to the LE Audio connect mode before pairing the receiver and headphones once again.
